LED Headlight not working
Postby tka126 - December 31st, 2016, 11:27 pm
Hello All,
I have a 2011 Escape and I had gotten a set of LED plug and go bulbs for xmas. I just went to install them and when I turned the lights on I got nothing out of either side. Any one have an idea why or how to fix this?
In case you need to know which ones here they are:
https://www.amazon.com/Turbo-9008-Headl ... ii+led+h13
Thank you in advance.
tka126
My nickname: Tim
My vehicle: 2011 Ford Escape XLT SAP
My vehicle's name: Scapey
Re: LED Headlight not working
Postby VD443H - January 2nd, 2017, 2:51 am
I had the same problem with a similar set. Turned out the polarity was reversed in the plug. I rotated it 180 degrees and it worked. I ended up sending them back since it wouldn't make a secure connection.
VD443H
My vehicle: 2003 Ford Escape XLT Yellow
Postby Barks507 - January 10th, 2017, 2:48 pm
Did you get them to work?
Barks507
My vehicle: 2009 Ford Escape 4cyl
Users browsing this forum: Google [Bot] and 2 guests
