2006 Escape XLT SPORT 4WD Engine Replacement
Engine, transmission, exhaust, drivetrain, more
Postby nckzizzo - December 14th, 2016, 9:56 am
Hey All! First time posting in a while since my '06 E has had a blown tranny and then a blown motor in a matter of 15 months :( I'm looking to completely replace my engine but soon after researching I found that there is 2 types of 3.0L V6 engine for my year. On "Car-part.com" it says that there is 2 variants (water pump driven by exhaust camshaft OR water pump driven by intake camshaft), It's says on both selection that the 8th digit should be a 1. How am I supposed to tell the difference?? I'm stumped and was wondering if anyone replaced this same engine before? Any help would be greatly appreciated!!!
nckzizzo
My nickname: Zizzo
My vehicle: 2006 Ford Escape XLT V6 4X4
My vehicle's name: Casper
Re: 2006 Escape XLT SPORT 4WD Engine Replacement
Postby 14theRoad - December 15th, 2016, 3:30 pm
Second post in the thread here shows pictures of how one vs the other looks.
http://www.escape-city.com/viewtopic.php?f=24&t=104
You may or may not have a tensioner on your Water Pump. The tensioner doesn't matter as it's recommended to remove it if/when you service the water pump and retrofit your water pump with an updated stretch belt configuration.
Postby nckzizzo - January 11th, 2017, 12:24 pm
Hey All! just wanted to update this as I have figured out my own issue! It turns out that after Jan 30, 2006 Ford decided to switch the water pump configuration. Pre 1/30/06 the water pump is driven off the intake camshaft and post 1/30/06 the water pump is driven off the exhaust camshaft. Both of these motors ARE interchangeable with one another.
nckzizzo
My nickname: Zizzo
Postby Big_burt87 - January 17th, 2017, 10:21 pm
NCKZIZZO, I am also in process of going threw the same issues finding a exhaust cam driven waterpump engine at an affordable cost. Where there any modifications that had to be made to put the intake cam driven water pump engine in your escape?
Also, I am curious if the 3.0l engine in the 2008 style escapes are compatible? I don't mean to hijack your thread, I'm just curious if anybody has tried or knows if that motor would work in my late 06 model.
Thanks
Big burt
Big_burt87
Return to Powertrain Mods
Users browsing this forum: Bing [Bot] and 2 guests
