2015 MKC 2.3L 6F35 Built On/Before 08/08/2014 Harsh Shift
Discuss your 2015 - Present Lincoln MKC here!!!!
Postby Domain - September 2nd, 2014, 5:33 pm
OASIS Broadcast wrote:Some 2015 MKC vehicles built on or before 8/8/2014 and equipped with 2.3L may exhibit a harsh shift or bump felt after the shift caused by the torque converter. Make sure the Adaptive Learning Drive Cycle (Workshop Manual Section 307-01) has been performed before evaluating the vehicle. If the concern is still present, follow this procedure: Vehicle must be at operating temp, Select the ‘S’ shiftbutton and use the manual shift paddles to select 3rd gear. Drive 15 mph, slightly depress accelerator pedal (Light Acceleration to 1500 rpm). At about 22 mph converter will start applying TCC (Torque Converter Clutch), at end of converterclutch apply is where the bump may occur. Repeat this drive procedure 5 times -- If a bump is felt replace the torque converter and use availble service labor times.
Domain
Current: 2014 Ford Taurus SEL AWD
Prior Fleet:
2005 Ford Five Hundred SEL AWD (now in Ohio)
2008 Ford Fusion SE AWD (total loss at hands of second owner)
2011 Ford Escape XLT AWD (sold, hopefully to a good home locally)
2013 Ford Taurus SEL FWD (sold, hopefully to a good home locally)
Fleet not owned, but cared for:
2010 Ford Escape XLT AWD (3.0L)
30 NY Counties - 3 States/Provinces - 2 Countries - 1 Escape
Need to pull more than just OBD Data? See this thread.
Thinking of putting HID's in your reflector headlamps? STOP! Read this first.
Is your vehicle under a Ford/Lincoln/Mercury recall? Check here.
Domain
First poster on E-C's THIRD new server
E-C LEVEL 7
Location: The Land of Snow, more commonly known as Buffalo, New York
My vehicle: 2014 Ford Taurus SEL AWD
My vehicle's name: The Bull
Return to Lincoln Lane
cron
