Permanently disable auto stop/start?
Postby Bionicrocky - June 30th, 2016, 10:55 pm
I tend to turn the auto start/stop off most of the time, manually poking the button. Does anyone know if there is a way to permanently/semi-permanently disable it? I don't pay for the gas for work or personal use and it's just not worth the annoyance to have it on.
Bionicrocky
My vehicle: 2017 SE 1.5 FWD Leather
My vehicle's name: Estelle
Re: Permanently disable auto stop/start?
Postby Jay2TheRescue - July 1st, 2016, 12:14 am
The EPA probably requires it to only be temporarily disabled. Auto Stop probably helped it get the EPA rating it has.
Jay2TheRescue
E-C LEVEL 10
Postby feh2goup - July 1st, 2016, 1:20 am
Bionicrocky wrote:I tend to turn the auto start/stop off most of the time, manually poking the button. Does anyone know if there is a way to permanently/semi-permanently disable it? I don't pay for the gas for work or personal use and it's just not worth the annoyance to have it on.
And the idea behind it was not to save you money. It was to lower carbon emissions, improve mileage and with a side benefit of reducing gas consumption. Who's against cleaner air?
2006 Suzuki Grand Vitara JLX-L, ~Maroon Red
2009 Escape Hybrid Limited AWD, Black, bought Jan.2013
- replaced ambient temperature sensor
- replaced hvac blend door motor
- updated SYNC software
- replaced water pump
- brake job
- replaced steering column
- replaced TPMS sensor
- multiple rear hatch water leaks fixed
- rattle in dashboard resolved as loose bolt in steering column coupler
- replaced underbody a/c lines to rear hvac
- replaced backup sensor
- replaced sway bar links
- replaced one outer tie rod (105,000 miles)
- replaced right front wheel bearing
- replaced ball joints
- another brake job
feh2goup
E-C LEVEL 5
Congratulations on reaching 750 posts!
Postby Charles - July 1st, 2016, 7:04 am
Check the settings on your 2017. If it doesn't list the ability to permanently turn on/off auto stop/start, it can't be done. :shrug:
Image Image
Present vehicles
2012 Buick Verano Leather Group - Black Onyx - Sunroof, Navigation, Premium Exterior Package, WeatherTech DigitalFit liners (1st & 2nd Row)
Charles
My nickname: Charles
My vehicle: 2016 Escape Titanium FWD 2.0L
My vehicle's name: Shadow
Postby rfruth - September 21st, 2016, 9:29 pm
I'm all for clean air but wonder how effective the A/C is when the auto start/stop has been on for 45 seconds or longer (like when sitting at a red light in traffic when its 95 degrees outside)
((I have a feeling I'll be using the disable button a LOT))
2017 Ti 2.0 4x2 300A
rfruth
E-C LEVEL 1
My vehicle: 2017 Escape FWD
My vehicle's name: Silver Bullet
Postby hangover2fanz - September 23rd, 2016, 9:46 am
I don't have my 2017 yet (hopefully picking it up tomorrow morning) but I read on another forum that when the transmission is in sport mode it doesn't allow auto stop/start to occur, so that is a sort of permanent deactivation if you drive in that mode all the time (which, i plan on doing anyway unless break in period doesn't allow it).
Maybe others could test that out and report back. If not, I most likely will :-)
hangover2fanz
Postby MadMax - September 23rd, 2016, 3:39 pm
hangover2fanz wrote:I don't have my 2017 yet (hopefully picking it up tomorrow morning) but I read on another forum that when the transmission is in sport mode it doesn't allow auto stop/start to occur, so that is a sort of permanent deactivation if you drive in that mode all the time (which, i plan on doing anyway unless break in period doesn't allow it).
This is good to know :yes:
Formerly: 2006 Mazda Tribute
E-C LEVEL 17
Postby Charles - September 23rd, 2016, 4:25 pm
Welcome to the City!!!! Glad you joined us!!! :yes:
:topic:
Image Image
Present vehicles
Charles
Postby hangover2fanz - September 26th, 2016, 11:09 am
I did pick up my Escape Saturday morning and i can confirm leaving it in sport automatically disables Auto Start/Stop and leaves it off while in that mode.
hangover2fanz
Postby bobump - October 10th, 2016, 2:59 pm
I found that if I turn on climate control the engine will take longer to go into auto off or not go off at all. Also pressing climate control often forces the car to start. LOL
That said, I'm pretty impressed with it. I do wish you could tweak the time it takes to shut off. Sometimes it's 1 second after a stop, but start up is seemless 99% of the time.
2010 XLT 203A package
AVS window rain guards
bobump
E-C LEVEL 1
My vehicle: '17 Lightning Blue SE 4WD 1.5L
Next
