Weight Distribution of Escape
Talk about anything related to your 2013 - 2016 Escape and 2012 - Present Kuga here!
Postby Charles - September 28th, 2016, 6:22 pm
I have looked all over the Interwebs looking for the approximate percentage weight distribution, front to rear, for the Gen 3 Escapes.
The reason I am asking relates to whether or not I can safely tow my 2016 Escape on a tow dolly equipped with Maxxis ST185/80R13 Load Range C tires. According to the Maxxis Trailer Tire Load/Inflation Chart, this particular tire can handle a load of 1,480 lbs at a cold inflation of 50 psi.
My best guess for the curb weight for my Escape is 3,582 lbs. I know FWD vehicles are heaver on the front axle than the rear. I have made calculations that show I should be good for 60% of the curb weight on the front axle, 65%, and 70%. Based on all three of these scenarios, I should be good with the Load Range C tires.
Does anyone know what the approximate front/rear weight distribution on this generation of Escapes? Is there any place on the Interwebs that lists this percentage?
Present Vehicle
2015 F450 Platinum Crew Cab Long Bed DRW, White Platinum Tricoat, 6.7L Powerstroke Diesel, 225/70R/19.5 tires, Almost every option known to man (except a sunroof). Ford 27.5K Fifth Wheel Hitch; AirRide LoadLifter 5000 Air Suspension System with LoadController Single Air Compressor System; BetterBuilt Aluminum Crossover Pickup Bed Tool Box
"19.5s are chick magnets"
Former Vehicles
2012 Buick Verano Leather Group - Black Onyx - Sunroof, Navigation, Premium Exterior Package, WeatherTech DigitalFit liners (1st & 2nd Row), Wireless Rear View Camera.
Charles
My nickname: Charles
Re: Weight Distribution of Escape
Postby MadMax - September 28th, 2016, 8:32 pm
I couldn't find anything specific to the Escape, but just about every other FWD crossover/SUV in it's class is 60/40, including the Edge. My guess is that the E is pretty close to that :shrug:
EDIT: Also the Focus which of course the E is based on is also 60/40
Formerly: 2006 Mazda Tribute
E-C LEVEL 19
Postby Charles - September 28th, 2016, 8:51 pm
MadMax wrote:I couldn't find anything specific to the Escape, but just about every other FWD crossover/SUV in it's class is 60/40, including the Edge. My guess is that the E is pretty close to that :shrug:
I suspect you are real close Max. I do plan on putting the Escape on the CAT Scale to get an actual weight on the front versus rear.
Like I said earlier, I "guestimated" based on 60%, 65%, and 70% front weight and am good for my Load Range C tire. My previous tire was a Load Range D which has 2 additional plies, is capable of handling more weight, has a higher maximum cold tire pressure, etc.
Present Vehicle
Former Vehicles
Charles
Postby Jay2TheRescue - September 29th, 2016, 11:19 pm
That's one thing I like about having a 4wd hybrid... The weight is more evenly distributed.
Jay2TheRescue
E-C LEVEL 10
Postby Charles - September 30th, 2016, 10:05 am
Jay2TheRescue wrote:That's one thing I like about having a 4wd hybrid... The weight is more evenly distributed.
Your Hybrid can be flat towed Jay according to Ford. Source: 2008 Ford Towing Guide, page 12. If my Escape could be flat towed in either the FWD or AWD configuration, I wouldn't be agonizing over this. :rant:
Present Vehicle
Former Vehicles
Charles
Postby Charles - September 30th, 2016, 12:19 pm
Wife came across this file on the Interwebs. Weight Guidelines.
What it says is this:
Determine the front end weight of your car to be towed. To do this you must weigh the front end of your car (at a truck stop, etc.). As an estimate, you can multiply the curb weight of your car by 62% for a front wheel drive, and by 52% for
a rear wheel drive car. These percentages are approximations and should not take the place of an actual weight.
Like I said before, I have made assumptions of 60%, 62%, 65%, 70%, 75% and 80% of the Escape's curb weight of 3,582 lbs biased to the front axle. And assuming a 50%/50% Left/Right weight distribution of the front axle weight, I can successfully use a Load Range C tow dolly tire safely to tow my Escape.
If I assume the front axle weight is distributed 55% / 45% (in other words, one side of the front axle has more weight than the other), I can not safely tow my Escape using the tow dolly for 75% and 80% of the Escape curb weight of 3,582 lbs biased to the front axle.
Present Vehicle
Former Vehicles
Charles
Postby Jay2TheRescue - September 30th, 2016, 5:16 pm
All FEH models are flat towable.
Jay2TheRescue
E-C LEVEL 10
Postby camusdarrach - September 30th, 2016, 5:26 pm
Over here, it's an offence to tow a vehicle behind a campervan / RV using a tow dolly, or A frame etc, due to anything being towed over 740kgin weight requires brakes that activate when the tow vehicle brakes.
The only exception is if the vehicle being towed has broken down during a journey, and is being taken either back home or to a garage to be repaired.
So we can only use a trailer to put a car on behind a campervan, but to me that is far safer, as well as easier to reverse etc.
So why not trailer the Escape.....?
The only member with both a RHD Maverick and LHD Escape
camusdarrach
E-C's only ambidextrous member and British Correspondent
E-C LEVEL 8
My vehicle: 2003 Ford Maverick 2.0 XLT,
My vehicle's name: 2002 Ford Escape 3.0 XLT Midni
Postby camusdarrach - September 30th, 2016, 6:28 pm
Thinking about towing etc, and recalling my vast experience in recovering all types of vehicles, from tractors to 40 ton arctic trucks, have you considered the centre of balance will be affected when the front end is raised up, i.e. loaded on the dolly.
The act of raising the front end will put more weight on the rear axle, and it can make a huge difference, just ask any tow truck driver.
Yes the front is supported on the road, but the vehicle isn't on the road as the manufacturer intended, and worse case scenario is damage to the rear wheel area, as the angle of contact is greater than was designed.
I mention this as I have in the past had to deal with damage by so called suspended tows, causes more damage than you think, especially over a period of time.
For towing your Escape, the best ans safest way is all wheels off the road, i.e. on a trailer.
Sorry.
camusdarrach
E-C LEVEL 8
Postby Charles - September 30th, 2016, 7:32 pm
camusdarrach wrote:Thinking about towing etc, and recalling my vast experience in recovering all types of vehicles, from tractors to 40 ton arctic trucks, have you considered the centre of balance will be affected when the front end is raised up, i.e. loaded on the dolly.
Sorry.
I wish I could flat tow the Escape but Ford says, Nooooo!!!! :doh:
Present Vehicle
Former Vehicles
Charles
Next
Return to 2013 - 2016 Escape / 2012 - Present Kuga General Discussion
