Ford Escape Headligt w/DRL's and Projectors
Talk about anything related to your 2013 - 2016 Escape and 2012 - Present Kuga here!
Postby sgsmith116 - June 10th, 2016, 11:56 am
New member here so my apologies if I did not properly insert the video link:
I have a 2013 Escape SEL with the standard reflector housing but wanted to put an HID kit it but do it correctly by putting it in a projector housing. After searching I came across some these lights which I saw on eBay but managed to get a much better price going through Alibaba. Unfortunately once receiving the lights and being told they were plug and play. They were not. The S and SE and SEL lights have two separate plugs that plug into the stock housing. After some research it turns out the plug required for this light is the same 14 pin used on the titanium. Managed to use posi-tap connectors to temporarily wiring the lights up and running a fuse tap to fuse 39 (DRL) I was able to get the lights to function as I hoped they would. Now to remove the bumper cover and install them permanently using solder and heat shrink.
https://www.youtube.com/watch?v=S-EaV1cI4Kg
sgsmith116
My vehicle: 2013 Ford Escape SEL AWD
Re: Ford Escape Headligt w/DRL's and Projectors
Postby Charles - June 10th, 2016, 12:24 pm
sgsmith116 wrote:
Moderator Message:
Embedded video. - Charles
Welcome to the City!!! We are glad you joined us!!! :welcome:
Image Image
Present vehicles
2012 Buick Verano Leather Group - Black Onyx - Sunroof, Navigation, Premium Exterior Package, WeatherTech DigitalFit liners (1st & 2nd Row)
Charles
My nickname: Charles
My vehicle: 2016 Escape Titanium FWD 2.0L
My vehicle's name: Shadow
Postby sgsmith116 - August 16th, 2016, 9:07 am
Got Everything Installed. Headlights AND Replaced my Fogs with these complete Fog Light replacements which have built in DRL's, Integrated Turn signals AND still retain the Fog Light Bulb. Next is to Put a 5000K 35 HID Kit in for the Low beams to match up with the LED Fog Light Bulbs. The lighting is a Huge Improvement and the High Beams are extremely impressive. Here's the video of the full function test.
Moderator Message:
Embedded video - Charles
sgsmith116
Postby Touringmike - August 16th, 2016, 6:04 pm
sgsmith116 wrote:New member here so my apologies if I did not properly insert the video link:
. Now to remove the bumper cover and install them permanently using soldier and heat shrink.
So, what exactly does the soldier do, he must be pretty darn small, or is he the guy who solders the wires?... :lol:
Looks good, wish there was a package like that for the '08-'12s
Touringmike
My vehicle: '11 Limited
Return to 2013 - 2016 Escape / 2012 - Present Kuga General Discussion
