wtf now.. Engine noise
Re: wtf now.. Engine noise
Postby Midshift - August 20th, 2016, 8:47 am
Squirrel wrote:Sounds like the serpentine belt tensioner bearing. Not PS or AC. Though, I wouldn't rule out the Clutch, but when my AC clutch went bad (on a different vehicle) it rattled more and did stop/start the noise if the AC was on/off.
If you can, hit up Harbor Freight and get one of these:
http://www.harborfreight.com/mechanics- ... 69913.html
It will help narrow down the location/cause. :thumb:
Comments about Pittsburgh Automotive Mechanic's Stethoscope:
used to isolate noise in accessory drive belt idler pully. works great
BOTTOM LINE Yes, I would recommend this to a friend
I guess it wouldn't exactly hurt if I spent like $10 (combined) and bought a turkey baster and some Mercon ATF and swapped out the fluid in the PS reservoir.
"Mods":
6000k Bi-Xenon HID Headlamps/Fogs (Diode Dynamics LLC - STL Mo)
Complete Vehicle Std--to--LED Bulb swap (SuperBrightLEDs - Maryland Heights Mo)
K&N Air Filter
Body molded mudflaps
Custom MTX/Kenwood Audio system
Weathertech floormats
Midshift
E-C LEVEL 5
My nickname: Midshift
My vehicle: '05 Mariner Luxury 4WD V6
My vehicle's name: Lil-4WD
Postby Squirrel - August 20th, 2016, 3:43 pm
While a turkey baster will work, I highly recommend this tool (I have and use) instead. You will find ALOT of other uses/needs for it as well. http://www.harborfreight.com/brake-flui ... 92924.html
Squirrel
E-C LEVEL 4
My nickname: Squirrel!
Postby Midshift - August 20th, 2016, 8:11 pm
Well, I just used an empty spray bottle and got the old fluid out of the reservoir at least.
Refilled it with some Lucas Oil PS Fluid, turned the wheel from lock to lock for like 5-10 minutes, drove around the block, doing some turns, parked it, went inside for like 4 hours, then did this all again...
Even if the PS didn't NEED to be changed, it is now changed (the simple change, not flushed)...
Engine noise def. seems to be coming from the beltline, I just cant figure out where...
I think I'm gonna hafta call a mechanic on Monday :(
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
Postby Midshift - September 7th, 2016, 5:59 pm
Mechanic thinks it the tensioner...
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
Postby MadMax - September 7th, 2016, 6:21 pm
Makes sense :yes:
Formerly: 2006 Mazda Tribute
E-C LEVEL 19
Postby Midshift - September 7th, 2016, 9:08 pm
MadMax wrote:Makes sense :yes:
So, I will be spending $70 on Friday for a tensioner and belt..
Yay for car parts :?
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
Postby Squirrel - September 7th, 2016, 11:33 pm
Had a feeling. :yes:
Enjoy the quiet engine again. :rockon:
Squirrel
E-C LEVEL 4
Postby Squirrel - September 7th, 2016, 11:38 pm
They aren't bad to replace. :thumb:
Squirrel
E-C LEVEL 4
Postby Midshift - September 8th, 2016, 7:31 pm
Yup. I buy the parts and my mechanic friend (been mechanic for 40+ years) will do the labor for roughly 1/2 to 1/4 of what a random shop would charge. :D
Sometimes it pays to have friends like that :yes:
Found a Dayco (89370) Tensioner from RockAuto..
I could go cheaper on the belt, but Dayco (5060840) PolyRIB belt from RockAuto..
Shouldn't be too bad unless he finds out something else is messed up (which at 87k* miles, I'd think not)
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
Postby Midshift - September 20th, 2016, 4:07 am
Work complete..
New Belt
New Belt Tensioner
New Idler Pulley ...........................................................................................
and its the AC Compressor ... :censor: :censor: :censor: :censor: :censor: :censor: :censor: :censor: :censor: :censor:
So, SOON I will be buying a compressor, for install. :cuss: :cuss: :cuss:
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
PreviousNext
Return to Mariner Manor
