wtf now.. Engine noise
Postby Midshift - August 12th, 2016, 9:48 am
So yesterday morning when I went out to my car to leave for work, it was making an abnormal rattle-rumble. It was roughly 0545 (I work at 0630) so I really didnt have much time to investigate.
This morning I pop my hood and the noise is coming from the left side of the Duratec. So now I get to play super-fun Ear game, " Try to diagnose that noise"..
I'm sure its on the beltline somewhere and/but I hope its not my Waterpump,A/C Clutch or my Power steering.
If this noise keeps up, looks like I'm gonna be taking her in to the Doc (mechanic) ..
A/C has suffered alot this summer, even after a recharge, so maybe it is the A/C Clutch.. :wall: :wall: :wall:
Edit: The noise doesn't seem to stop when I turn off the A/C, so that might not be it.. fuq
"Mods":
6000k Bi-Xenon HID Headlamps/Fogs (Diode Dynamics LLC - STL Mo)
Complete Vehicle Std--to--LED Bulb swap (SuperBrightLEDs - Maryland Heights Mo)
K&N Air Filter
Body molded mudflaps
Custom MTX/Kenwood Audio system
Weathertech floormats
Midshift
E-C LEVEL 5
My nickname: Midshift
My vehicle: '05 Mariner Luxury 4WD V6
My vehicle's name: Lil-4WD
Re: wtf now..
Postby HuntingEscape - August 12th, 2016, 9:53 am
any other symptoms other than noise? dimming lights, loss of engine power, rough idle, leaking fluids?
HuntingEscape
E-C LEVEL 1
My vehicle: White 2009 Escape XLT
My vehicle's name: Sid
Re: wtf now..
Postby Midshift - August 12th, 2016, 10:00 am
HuntingEscape wrote:any other symptoms other than noise? dimming lights, loss of engine power, rough idle, leaking fluids?
I have not noticed any fluids or an abnormal idle.
Have had a door ajar issue but thats most likely completely irrelevant.
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
Re: wtf now.. Engine noise
Postby boogie_4wheel - August 12th, 2016, 12:17 pm
I had a serpentine belt stretch, and the rattling was from the tensioner running out of room to take up the slack. It was at the end of its travel so it beat against the end of its rotation ability and made a hell of a noise.
'05 3.0L/Auto, AWD, 262k, stock engine and trans
boogie_4wheel
E-C LEVEL 3
My nickname: Stoner
My vehicle: 2005 XLT 3.0L AWD
Postby MadMax - August 12th, 2016, 5:24 pm
boogie_4wheel wrote:I had a serpentine belt stretch, and the rattling was from the tensioner running out of room to take up the slack. It was at the end of its travel so it beat against the end of its rotation ability and made a hell of a noise.
Escapes/Mariners have timing chains and not belts, so I doubt that's the problem
Formerly: 2006 Mazda Tribute
E-C LEVEL 18
Postby Touringmike - August 13th, 2016, 7:51 am
Hmmmm.
Mine has a serpentine belt. (more commonly referred to as a Fan belt).
I would think though, if the belt was stretched enough to make a loud noise, you'd have weak or flickering lights,
lousy steering, bad AC, etc.
My guess would be a bad bearing on something.
Time for probing with a metal stick to find the culprit.
:thumb:
Touringmike
My vehicle: '11 Limited
Postby Midshift - August 13th, 2016, 12:10 pm
Touringmike wrote:Hmmmm.
:thumb:
I do have s_hitty AC..
Here's a video I just took..
You hear the sound best beginning at :09 ....
https://youtu.be/tUmcUF7F9-Q
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
Postby Midshift - August 13th, 2016, 9:42 pm
Whatever it is, I pray it's not too expensive
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
Postby Midshift - August 14th, 2016, 2:51 pm
Possibly power steering pump?
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
Postby Squirrel - August 14th, 2016, 6:55 pm
Sounds like the serpentine belt tensioner bearing. Not PS or AC. Though, I wouldn't rule out the Clutch, but when my AC clutch went bad (on a different vehicle) it rattled more and did stop/start the noise if the AC was on/off.
If you can, hit up Harbor Freight and get one of these:
http://www.harborfreight.com/mechanics- ... 69913.html
It will help narrow down the location/cause. :thumb:
Comments about Pittsburgh Automotive Mechanic's Stethoscope:
used to isolate noise in accessory drive belt idler pully. works great
BOTTOM LINE Yes, I would recommend this to a friend
Squirrel
E-C LEVEL 4
My nickname: Squirrel!
Next
Return to Mariner Manor
