Air Bag light
Air Bag light
Postby Midshift - December 5th, 2015, 11:03 pm
Went into a store tonight, came back out and AB light was on..
I did previously run car through a car wash, so I'm unsure that had an effect after letting it sit for 10 mins as I went into the store..
Anybody know if anything other than impact would trigger that? With the cold weather, it will probably be off when I head to work at 0600 tomorrow. :shrug:
'05 Mariner Lux
"Mods":
6000k Bi-Xenon HID Headlamps/Fogs (Diode Dynamics LLC - STL Mo)
Complete Vehicle Std--to--LED Bulb swap (SuperBrightLEDs - Maryland Heights Mo)
K&N Air Filter
Body molded mudflaps
Custom MTX/Kenwood Audio system
Weathertech floormats
Midshift
E-C LEVEL 5
My nickname: Midshift
My vehicle: '05 Mariner Luxury 4WD V6
My vehicle's name: Lil-4WD
Re: Air Bag light
Postby MadMax - December 6th, 2015, 1:11 am
According to your owners manual...
Seating and Safety Restraints
The front passenger sensing system may detect small or medium objects
placed on the seat cushion. For most objects that are in the front
passenger seat, the passenger airbag will be disabled. Even though the passenger airbag is disabled, the pass airbag off light may or may not be illuminated according to the table below.
Objects.....Pass Airbag Off Indicator Light.....Passenger Airbag
Empty seat ..............unlit..................................Disabled
Small (i.e. 3 ring
binder, small purse,
bottled water)...........unlit..................................Disabled
Medium (i.e. heavy
briefcase, fully packed
luggage)....................lit..................................Disabled
Empty seat, Small or
medium object with
safety belt buckled.......lit..................................Disabled
In case there is a problem with the
passenger sensing system, the
airbag readiness light in the
instrument cluster will stay lit. DO
NOT attempt to repair or service the system; take your vehicle
immediately to the dealer.
In case there is a problem with the passenger sensing system, the airbag
readiness light in the instrument cluster will stay lit. DO NOT attempt to
repair or service the system; take your vehicle immediately to the dealer.
If it is necessary to modify an advanced front airbag system to
accommodate a person with disabilities, contact the Ford Customer
Relationship Center at the phone number shown in the Customer
Assistance section of this Owner's Guide.
Formerly: 2006 Mazda Tribute
E-C LEVEL 18
Re: Air Bag light
Postby Midshift - December 6th, 2015, 8:15 am
thx
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
Re: Air Bag light
Postby RobtRoma - December 7th, 2015, 2:09 pm
I had the airbag warning light on the dash come on at one point. All my research pointed towards the seat belt tensioner. Then I read a quick blurb about the connection under the seats coming lose, especially if you tend to store things under your seat. At the time, I had a small, travel type dumbbell set in a case under the passenger seat. I removed the case and pushed the under-seat connectors together. The warning light went away and stayed away. I hope your issue is as simple as mine was.
The real art of conversation is not only to say the right thing at the right time,
but also to leave unsaid the wrong thing at the tempting moment...
RobtRoma
Super Moderator and E-C's 100,000th AND 200,000th Poster
My nickname: Rob
My vehicle: 2002 XLT 4x4
My vehicle's name: The Mean Green Machine
Re: Air Bag light
Postby Midshift - December 7th, 2015, 5:30 pm
RobtRoma wrote:I had the airbag warning light on the dash come on at one point. All my research pointed towards the seat belt tensioner. Then I read a quick blurb about the connection under the seats coming lose, especially if you tend to store things under your seat. At the time, I has a small, travel type dumbbell set in a case under the passenger seat. I removed the case and pushed the under-seat connectors together. The warning light went away and stayed away. I hope your issue is as simple as mine was.
Don't know what it was, but the issue solved itself overnight.
Thx for input peeps.
"Mods":
K&N Air Filter
Midshift
E-C LEVEL 5
Re: Air Bag light
Postby AhuraMazda04 - December 22nd, 2015, 1:13 pm
look for code 46 or 45. Common on mine. The light flashes in code when the ignition is turned on. 45 is driver seat connector and 46 is passenger seat connector. The light flashes in a sequence of fast flashes and slow flashes, the first set are the first number and the second set are the second number.
Zoom, Zooom, Zoom!!!
Mazda Tribute 2001-2006= What you get when an SUV is raised by a family of sports cars.
Before:
After:
AhuraMazda04
E-C LEVEL 4
My vehicle: 2004 Mazda Tribute LX FWD
Re: Air Bag light
Postby Heff_Me - December 30th, 2015, 4:24 pm
I have experienced the same thing multiple times, turning the car off and restarting it a couple minutes later seems to solve the problem. I think there is a loose connection underneath the seat.
Heff_Me
My nickname: Heff
My vehicle: 2008 Mercury Mariner
Re: Air Bag light
Postby Stryfe - April 26th, 2016, 5:47 pm
I know this thread is 4 months old, but I just wanted to say thank you guys. This was something that made me worry about the wife's E!
2004 Ford Escape - 3.0, 4x4, Redfire Metallic/Gray Metallic two-tone (No mods except Pioneer Head Unit)
2005 Mercury Mariner - 3.0, 4x4, Gray Metallic (Daily)
2002 Ford Escape - 3.0, 4x4, Dark Green (Parts)
Stryfe
My vehicle: 04 E, 05 M, 02 E
Return to Mariner Manor
