Jeep Wheels
Jeep Wheels
Postby Twister - December 16th, 2016, 3:07 am
Looking for a second set of wheel for my 2003 E so i can mount a set of winter tires. I came across a set of jeep wheels for very cheap and was wondering if anyone had used these wheels on their escapes. These are the ones i am thinking of picking up.
Twister
My vehicle: 2003 Ford Escape XLS Sport
Re: Jeep Wheels
Postby Escape94 - December 16th, 2016, 10:55 am
So long as the bolt pattern matches up you should be fine.
Side note: what Jeep were those on? :?
Currently:
Escape94
E-C LEVEL 8
Re: Jeep Wheels
Postby backroad101 - December 16th, 2016, 1:06 pm
These look like 90's Jeep (non-Grand) Cherokee wheels
http://media.ed.edmunds-media.com/jeep/ ... _1_500.jpg
2011 Escape XLT
http://www.escape-city.com/viewtopic.php?f=23&t=23610
backroad101
E-C LEVEL 4
Re: Jeep Wheels
Postby underthetire - December 17th, 2016, 2:37 pm
Offset it going to be different. Jeep Cherokee was a 20 offset, escape is ~40, so they will stick out further. Those were based on a rwd platform.
Sent from my A3-A20FHD using Tapatalk
underthetire
E-C LEVEL 8
My vehicle: 2009 xlt sun and sync 2.5
My vehicle's name: Money saver
Re: Jeep Wheels
Postby Twister - December 18th, 2016, 2:51 am
underthetire wrote:Offset it going to be different. Jeep Cherokee was a 20 offset, escape is ~40, so they will stick out further. Those were based on a rwd platform.
Is that a large difference with the offset? I am new to the whole wheel offset/backspacing. Will they stick out a lot of just a little bit more.
Twister
Re: Jeep Wheels
Postby Escape94 - December 18th, 2016, 9:38 am
They'll probably stick out jut under a half inch. Do you know what bolt pattern those are? That should be your biggest concern.
Currently:
Escape94
E-C LEVEL 8
Re: Jeep Wheels
Postby Twister - December 18th, 2016, 4:36 pm
Escape94 wrote:They'll probably stick out jut under a half inch. Do you know what bolt pattern those are? That should be your biggest concern.
Yes they are 5x4.5
Sent from my SM-N910P using Tapatalk
Twister
Re: Jeep Wheels
Postby underthetire - December 18th, 2016, 5:03 pm
20mm more would be just over 3/4 inch over a 40 offset, however, looking up offsets, the Escape of your year can be a 42 or 45 offset, so your going to be closer to an inch more. I'm sure they will work, but it's up to you if they look OK.
underthetire
E-C LEVEL 8
Return to Tires And Rims
