Tire Advice
Tire Advice
Postby Redneck Ginger16 - November 16th, 2016, 8:18 pm
Ive got an 04 Escape XLT 4x4 with 235/70r16 on it now but wanna look at putting some more meaty tires on it. Was looking at putting 235/75r15 with pro comp steelies. Will that work ? Or is there any more aggressive tires in stock size or will other sizes work that i can get a more aggressive look ?
Any advice will be much appreciated. Thanks
Redneck Ginger16
My vehicle: 2004 Ford Escape XLT 4x4 V6
Re: Tire Advice
Postby Escape94 - November 16th, 2016, 8:25 pm
:hi: :welcome: :hi:
I currently run 235/75/16 Firestone Destination A/Ts with no complaints. 235/75/15 or maybe even 245/70/15 should work. The 15" wheels should look nice I think that's what came on the XLS trim level so you should be good there. Also any tire shop should be able to test fit for you. Good luck!
Currently:
R.I.P 6/15/2017 :(
Escape94
E-C LEVEL 8
My vehicle: 2011 Escape LTD V6 4x4
Re: Tire Advice
Postby Redneck Ginger16 - November 16th, 2016, 8:46 pm
How is your speedo running the tires you have ? Because ive installed pro comp steelies on escapes at the shop i work at but they were 16" so i might go with those as well but i wanna find a more aggressive tire like a mud tire to put on it but there isnt much selection in stock size so i was looking at 235/75r15 or other sizes that will work that offer a mud tire selection
Redneck Ginger16
Re: Tire Advice
Postby Escape94 - November 17th, 2016, 9:12 pm
My speedometer "may" be off just slightly but not a big enough change for me to care.
Currently:
R.I.P 6/15/2017 :(
Escape94
E-C LEVEL 8
Re: Tire Advice
Postby Redneck Ginger16 - November 18th, 2016, 10:43 pm
Well as long as the speedo isnt out by a lot im not very worried im just trying to find the most aggressive style tire i can find in a size that wont rub or throw out my speedo a lot
Redneck Ginger16
Tire Advice
Postby AusEscape - November 19th, 2016, 3:45 am
I have Firestone Destination A/T as well. Mine are only 215/70 r16. They go well off road and are still good on the highway.
The tread looks chunky enough.
Although mine are a little skinny but that's what were on it.
I run 38psi on the road and 25psi off road.
AusEscape
My vehicle: 2005 Ford Escape XLS 4x4 2.3L
Re: Tire Advice
Postby Redneck Ginger16 - November 19th, 2016, 5:21 pm
Thanks for all your inputs im gonna be putting LT225/75r16 Cooper Discoverer STT Pro mud terrians on Pro Comp steel wheels. I think it will be a very nice setup
Redneck Ginger16
