Help! 235 to 255 Need answer soon !
Postby AhuraMazda04 - September 13th, 2016, 2:00 am
Okay this time I'm altering my tire size from 235/70 16 to 255/65 16
The speedometer should be accurate and from the measurements I collected they should fit.
Has anyone else done this and will the tires rub? :?
Zoom, Zooom, Zoom!!!
Mazda Tribute 2001-2006= What you get when an SUV is raised by a family of sports cars.
Before:
After:
AhuraMazda04
My vehicle: 2004 Mazda Tribute LX FWD
Re: Help! 235 to 255 Need answer soon !
Postby AmauryJVL - September 18th, 2016, 1:46 am
The speedometer will be true, i have them on my factory wheels but with 25mm spacers, if i am not mistaken you could run them with 5mm spacers and it wont rub. again i am not 100% sure
Here is a picture of the 5mm spacers that are hub centric (67.1)
2010 Escape XLS Steel blue, My instagram and Twitter feed.
AmauryJVL
My vehicle: 2010 Ford Escape XLS
My vehicle's name: La Escape (The Escape)
Postby AhuraMazda04 - December 27th, 2016, 9:40 pm
Thanks! Fit fine without spacers with room to spare. Lost a bit of steering response but gained a good amount of stability cornering . Might go wider next time with a wider rim to compensate for the excess sidewall
Before:
After:
AhuraMazda04
