Will 245/70 R16's Rub with stock height?
Postby WhatsAJeep - February 12th, 2016, 1:24 am
just ordered 1.5" strut spacers but they wont be here until next Friday. This weekend I'm going to get new tires, tie rod ends, and an alignment done. if I get 245/ 70R16 size tires will they rub??
"I know its not a Jeep but I sure as hell treat it like one"
WhatsAJeep
My nickname: Rob
My vehicle: 2009 Mercury Mariner Premier
Re: Will 245/70 R16's Rub with stock height?
Postby TexasGator - February 17th, 2016, 12:42 am
You can go to a 245/75r16 without rubbing.
Mods
    K&N Air Filter | EBC Green Stuff Pads | EBC Vented Rotors | CarField Strut Tower Brace | 245/75R16 BF Goodrich T/A KO2's | Limited Roof Rack | Limited Rear Lift-Gate Trim | Limited Fog Lights |JBL MS-62C 6.5" Component Speakers | Polk DB521 Rear Speakers | 2 Dayton Audio NS270-44 10" Neodymium Low-Profile DVC Subwoofers | Pioneer GM-D8601 Class D Mono Amplifier | Pioneer GM-D8604 Class FD 4-Channel Bridgeable Amplifier | XS Power D1200 AGM Battery | Scosche EFX Battery Terminals | Husky WeatherBeater Floor Mats | Black Gorilla Lug Nuts | Drake Off Road Billet Antenna | Black Billet Fender Washer Kit | Custom 2.5L Engine Cover | Gunmetal Billet Oil Cap | Super Bright LED's 194 LED Bulb w/ Focusing Lens Reverse Lights | ProBolt Black Engine Bay Nuts | Yakima Front Loader Bike Rack | Custom Black Plasti-Dip Accents | Custom Black Painted Rotors, Calipers and Drums | Custom Black Painted Engine Covers and Oil Dip Stick | Gator Badge
TexasGator
E-C LEVEL 4
My nickname: Gator
My vehicle: 2011 Ford Escape XLS
Postby Kareem_abdul_jabroni - January 1st, 2017, 5:38 pm
Hi all,
New here and still exploring. I'm seeing a lot of threads confirming that the 245/75r16's will work just fine. I just wanted to confirm that you are putting these on 16x7 rims and that these will fit without rubbing on a 2003 XLT.
There is a leveling kit install coming soon, already have most parts I need, but would like to make sure the tires will fit regardless.
Thanks all!
My nickname: Jason
My vehicle: 2003 Ford Escape XLT
Postby jaymo7923 - January 18th, 2017, 11:19 pm
I've got 245/70 Falken Wildpeak A/T on XD 16x8 0 offset at stock height and they only rub ever so slightly turned all the way right. 1.5-2" strut block might clear it or a small spacer.
http://s1255.photobucket.com/user/MoNKG ... j.jpg.html
http://s1255.photobucket.com/user/MoNKG ... t.jpg.html
jaymo7923
My nickname: Monk
My vehicle: 2002 Ford Escape XLT
Postby text_missing - January 24th, 2017, 9:33 am
they dont rub on mine, dont see how they would rub on yours
text_missing
My vehicle: 2006 mazda tribute i
My vehicle's name: Rocky
Postby fknizner - February 1st, 2017, 4:18 pm
Just got Canuck Motorsports front and rear coil springs installed, and about to put on some 245/70R16 Cooper Discoverer AT3's on Pro Comp Serires 32 16x8 0mm offset rims.
Based on the lift I'm getting from the CM springs (measured ~1.5" in the front and ~1") I think these will not rub at all.
fknizner
My vehicle: 2009 Ford Escape XLT
Postby fknizner - February 1st, 2017, 4:40 pm
jaymo7923 wrote:I've got 245/70 Falken Wildpeak A/T on XD 16x8 0 offset at stock height and they only rub ever so slightly turned all the way right. 1.5-2" strut block might clear it or a small spacer.
How far outside the fenders do our wheels stick out with your 16x8 0mm offset rims? I cant exactly tell from the first pic you linked to. I'm about to install a similar wheel setup, and am curious how they will look.
Also, have you had any issues with the wheel bearings, CV joints, or anything else, as a result of the heavier/greater offset rims and heavier tires?
Thanks!
fknizner
Return to Tires And Rims
