Horn upgrade
Horn upgrade
Postby lamg55 - August 28th, 2013, 12:22 am
Has anyone upgraded there horn? I would like too. Seems a bit too dinky. Any suggestions?
Ford Escape Hybrid Awd
Black on Black with Navigation, Heated Seats
Tinted Front windows to match rears
Completely De-badged
K&N Drop-in Air Filter
Custom Smoked Out Tail lights
Blacked Out Upper and Lower Billet Grill
HID 6000k Head lights
HID 3000K Fog Lights
Dome Lights replaced to LEDs
Front Strut Tower Bar installed
Recently:
Installed Trick LED Switch Back turn signals
Next - Rims and a Drop...
lamg55
My vehicle: 2006 Ford Escape Hybrid Awd
My vehicle's name: HiBird
Re: Horn upgrade
Postby Jay2TheRescue - August 28th, 2013, 12:32 am
I hear the limited models had a better horn. You can probably get one from a scrapyard for cheap, and it would be a direct replacement. Personally, I was thinking about getting a small air horn and wiring it up in there.
Jay2TheRescue
E-C LEVEL 10
Re: Horn upgrade
Postby tang - August 28th, 2013, 12:44 am
Here's what I have on record:
2008 - 9L8Z 13832 A $28.50
2009+ - 9L8Z 13832 B $44.48 (Stage 1)
2009+ - 9L8Z 13832 C $49.10 (Stage 2)
I wonder if the 2006 is the same as the 2008.
PM with wheel questions.
past: 09 Escape XLT V6 AWD
present: 15 Taurus SEL AWD
tang
E-C LEVEL 16
My vehicle: 09 ESC XLT 4WD V6
Re: Horn upgrade
Postby lamg55 - August 28th, 2013, 7:44 pm
I had an Hella brand air horn installed once in my Lexus. It was so loud! It sounded like a truck trumpet horn. I couldn't pass inspection in New Jersey until I unplugged it and plugged the original one back in. Fortunately for me I was able to do it in the parking lot.
I was looking on Amazon they have these this Freeway Blaster for 15 dollars.
Then they have High and Low horns. Question is would I need both to get a good quality sound? I guess I cant buy one without the other?
http://www.amazon.com/FIAMM-72112-Freew ... uto_text_z
Recently:
lamg55
Re: Horn upgrade
Postby underthetire - August 29th, 2013, 11:02 am
underthetire
E-C LEVEL 8
My vehicle: 2009 xlt sun and sync 2.5
My vehicle's name: Money saver
Re: Horn upgrade
Postby ExplorerTom - August 29th, 2013, 7:06 pm
I had the Hella Supertones on my Protege. Definitely louder than the Protege factory horn.
ExplorerTom
E-C LEVEL 6
My vehicle: '06 Mariner & '12 Escape
Re: Horn upgrade
Postby RonB - September 7th, 2013, 11:16 am
I bought the cheep three trumpet air horns and only used the two smaller ones to make it sound like a Ferrari horn. Was thinking of painting my E Ferrari red and putting on the badges. Would call it (Ferrar E)
If it don't work, make it work.
Open the throttle not the bottle
RonB
My nickname: Don't have one
My vehicle: 03 Escape XLT
My vehicle's name: Four Play
Re: Horn upgrade
Postby feh2goup - September 7th, 2013, 6:23 pm
Jay2TheRescue wrote:I hear the limited models had a better horn. You can probably get one from a scrapyard for cheap, and it would be a direct replacement. Personally, I was thinking about getting a small air horn and wiring it up in there.
I have a Limited, and the horn is, um, "pathetic" comes to mind. In fact, I thought it probably had two horns and one had stopped working. Turns out, the Escape has only one horn. Dual horns allow resonance between them for more volume and a richer sound. Of course dual horns cost more, weigh more and use more power.
2006 Suzuki Grand Vitara JLX-L, ~Maroon Red
2009 Escape Hybrid Limited AWD, Black, bought Jan.2013
- replaced ambient temperature sensor
- replaced hvac blend door motor
- updated SYNC software
- replaced water pump
- brake job
- replaced steering column
- replaced TPMS sensor
- multiple rear hatch water leaks fixed
- rattle in dashboard resolved as loose bolt in steering column coupler
- replaced underbody a/c lines to rear hvac
- replaced backup sensor
- replaced sway bar links
- replaced one outer tie rod (105,000 miles)
- replaced right front wheel bearing
- replaced ball joints
- another brake job
feh2goup
E-C LEVEL 5
Congratulations on reaching 750 posts!
Re: Horn upgrade
Postby FRENCHY - September 7th, 2013, 6:41 pm
I also have a Limited, I don't know if I have a dual horn, but I can say that I have two notes, a B and a G :thumb: That make a major 3rd in the musical language, and it also means it is a happy horn :thumb:
And It sounds good :thumb:
Pics of my E viewtopic.php?f=11&t=7758&start=30#p366903
FRENCHY
My nickname: Frenchy
Re: Horn upgrade
Postby Mantruck101 - September 7th, 2013, 9:08 pm
They upgraded the horn sometime between 2008 and 2010. Dad's 2008 has the dinky single horn whereas my 2010 has the dual horns.
Current: 2013 Volvo XC60 T6 AWD - 49K
Sold: 2010 Escape XLT V6 4WD -125K+ miles when I handed over the keys :-(
Mantruck101
E-C LEVEL 7
Congratulations on reaching 1,500 posts!
My vehicle: 2013 Volvo XC60 T6 AWD
My vehicle's name: The Meatball
Next
Return to Audio/Video Mods
Users browsing this forum: MSNbot Media and 5 guests
