I have a 2011 limited EC and I went through a car wash today and just out of no where 10 minutes after getting a car wash the rear right speaker was giving a very loud popping noise and then a A loud pitch and then a loud buzzing noise. It stays on for while and didn't go off I tried turning off the car and the sound was still there but fading away. I turn off the radio by removing the security insert as I have a avic x930bt and the sound faded away but was still there. Eventually it was just a low buzzing noise and then it turned off. This speaker is in the trunk it's not the one that is in the back right door, so not sure if because water is getting in there or the speaker is blown If so is it under warranty even though I got an after market HU. What can I do to test the speaker. I should
Mentioned I installed a backup camera and ran the wire on the side of the tube that goes from the top of the trunk to inside of the vechile I made sure I put silicon around the plug
So water can't get in, this was done almost 2 months ago. Any help will will
Be much appreciated. Can it be the amp as its near the back right speaker?
