2008 mercury mariner vibration
Postby dirtstocker73 - December 1st, 2016, 11:40 am
i have a 2008 Mariner. V6 AWD. has a very bad vibration at around 40-45mph. and gets worse, vibrates so bad you cant see straight. u-joints have been replaced and driveshaft balanced. rear diff has been replaced (used). swapped wheels and tires from another truck. front halfshafts have been replaced. pto has been replaced (used). nothing has changed the vibration except for removing driveshaft and driving without it. which is a lot better. any suggestions? maybe driveshaft is no good even tho its been balanced ? thanks
dirtstocker73
Re: 2008 mercury mariner vibration
Postby Charles - December 1st, 2016, 5:19 pm
First of all, welcome to the City!!!! :welcome: Sorry you are having issues with your Mariner.
I am moving your thread to our Problems and Solutions forum to increase the likelihood of getting an answer to your question.
Present Vehicle
2015 F450 Platinum Crew Cab Long Bed DRW, White Platinum Tricoat, 6.7L Powerstroke Diesel, 225/70R/19.5 tires, Almost every option known to man (except a sunroof). Ford 27.5K Fifth Wheel Hitch
"19.5s are chick magnets"
Former Vehicles
2012 Buick Verano Leather Group - Black Onyx - Sunroof, Navigation, Premium Exterior Package, WeatherTech DigitalFit liners (1st & 2nd Row), Wireless Rear View Camera.
Charles
My nickname: Charles
Postby MTNEscaped - December 1st, 2016, 8:24 pm
dirtstocker73 - Today, 11:40 am
Another welcome.
:welcome:
With the driveshaft out how much slop in the output shaft / yoke to the driveshaft?
Tried having a transmission shop look at it? :?
2008 Ford Escape XLT 4WD
Plain Jane with K & N filter / Optima yellow top battery / Goodyear Gatorback serpentine belt / Sensen front struts
30+ years of ford parts that do me no good at all on MTNEscaped !
MTNEscaped
E-C LEVEL 3
My nickname: Mtnman
My vehicle: 2008 XLT Escape 4WD
My vehicle's name: MTNEscaped
Postby 14theRoad - December 2nd, 2016, 1:16 pm
Another welcome.
:welcome:
I would assume that whoever balanced the drive shaft also indexed it correctly back into the drive train? Have you tried simply rotating the shaft a quarter turn in the mounting holes to see if any of the positions reduce the vibration?
Also, there's a pinion angle that may need to be checked and adjusted.
Pinion angle is the angle of the shaft in relation to the output shaft of the Transmission and the Pinion flange of the differential. If that angle is off you can get noise and vibration.
Start with the indexing first. You can do that at home on your own. Check the transmission flange and pinion flange for marks to see if first they are aligned. If not, align them, with the shaft off, then install the shaft and index it if needed.
If no marks exist, just clock the shaft until you get less or no vibration.
if that doesn't work, have the pinion angle checked by a reputable Driveline shop.
14theRoad
E-C LEVEL 4
Postby Squirrel - December 3rd, 2016, 6:13 pm
What kind of vibration? Is it thru the whole car? Is it only thru the steering wheel? Are the tires wearing oddly?
Squirrel
E-C LEVEL 4
My nickname: Squirrel!
Users browsing this forum: wptski and 38 guests
