spark plugs
spark plugs
Postby Canuck - December 7th, 2015, 11:57 am
I have 2003 Escape V6 with 60,000 miles. The spark plugs have never been changed. Should they be changed based on age?
The Escape runs well.
Canuck
Re: spark plugs
Postby JohnCT - December 7th, 2015, 2:14 pm
Canuck wrote:I have 2003 Escape V6 with 60,000 miles. The spark plugs have never been changed. Should they be changed based on age?
Plugs in aluminum heads should be pulled every 4 years or so, just to keep them from permanently welding themselves into the heads. While plugs don't age, they should have been pulled or replaced at least twice by now.
John
JohnCT
E-C LEVEL 4
My nickname: John
My vehicle: 2004 Tribute 2005 Tribute S
Re: spark plugs
Postby Escapeism - December 7th, 2015, 10:16 pm
And I believe you pull them with a cold soaked engine.
2013 Escape Titanium 2.0 4WD - Build Date 09/2012 - Ginger Ale - Panoramic Roof - Tow Package - Roof Racks - Mud Flaps - Husky Weatherbeaters - Kuga Rear LED Tail Lights - Body Color Rear Spoiler - Kuga Rear Fog Lights - LockPick Rear Camera - Added Factory NAV
Escapeism
E-C LEVEL 4
My vehicle: 2013 Escape Titanium 4WD
Re: spark plugs
Postby tomw - December 8th, 2015, 12:02 pm
If you decide to pull them just to make sure they don't stick, it might be worthwhile to use a torque wrench while loosening them. On the 4.6 with the plug sticking and falling apart problem, they limit the torque to 35ft/lb, and stop, tighten 1/4 turn, and add more penetrating oil, WD-40, PBBlaster, or ATF/Acetone 50-50 mix and wait. More waiting is good, as it will allow any 'sticky' to get softened by the penetrant, and possibly allow removal of the plugs without them disintegrating and leaving a shell inside... spelled expensive.
Along the same lines, if you are pulling the plugs, and they don't want to come out smoothly, by HAND, (using a socket and extension for access), then I'd throw some penetrant as above on them, and go inside and goof for a 1/2 hour, and then try again. You might just save the aluminum threads on your head by taking your time.
If you get them out successfully, be sure to glop on some anti-seize compound to the next time won't be a problem. Two cents, please.
tomw
E-C LEVEL 7
Location: NW Atlanta GA burbe - toenails of the foothills
My nickname: tom
My vehicle: 07 mariner 2wd v6
My vehicle's name: moby the white whale
Users browsing this forum: Google [Bot] and 23 guests
