Vehicle Lifting Points
Re: Vehicle Lifting Points
Postby tang - December 6th, 2011, 1:45 pm
If I were to guess, you guessed the right door.
PM with wheel questions.
past: 09 Escape XLT V6 AWD
present: 15 Taurus SEL AWD
tang
E-C LEVEL 16
My vehicle: 09 ESC XLT 4WD V6
Postby haukap8 - December 6th, 2011, 1:48 pm
There are velcro straps in there, so I would assume...
haukap8
E-C LEVEL 7
My nickname: Noah
My vehicle: 2009 Ford Escape XLT V6 4WD
My vehicle's name: Erin 2.0
Postby Stinky3377 - May 15th, 2012, 11:44 am
doru wrote:I have no problems lifting my other car on jackstands. However, I was never able to lift my Tribby.
I know it sounds trivial, but can someone post a step-by-step DIY (with pics) on how to place this particular car (SUV) on jackstands?
Like the whole 4 corners on jackstands.
It seems I am not the only one having difficulties with this.
This. :?
I'm going to replace the front brakes and need a picture of where/how to place a jack stand if I'm using designated jacking location with the supplied emergency jack. Thanks.
2005 Escape 3.0 V6 XLT 4WD
Stinky3377
Postby MDSCAPE12 - August 8th, 2012, 4:41 pm
Some Photos of the Factory installed lifting points direct from the owners guide.
Rear passengers side. The flouroscent orange area is where the jack pad rests on. Drivers side similiar.
Front Passengers side......Drivers side Similiar.....
MDSCAPE12
E-C LEVEL 10
My vehicle: 2013 Taurus SEL FWD V6
My vehicle's name: Keeping WARWAGON FOR NOW.
Postby ClutzCargo55 - August 23rd, 2012, 12:24 am
I have a question about raising the front end of the vehicle. There is a short, fairly beefy looking piece of U beam that is located rearward of the engine/transaxle (4 cylinder 2005 Escape) that looks sturdy enough to place the cradle of a floor jack underneath and raise up the vehicle. Does anyone know if this angle iron is structurally sound enough to use as a jacking point? I have included a photo of the prospective lift point.
http://s8.postimage.org/6nwf0uy05/Jackpoint.jpg
ClutzCargo55
Postby doru - October 19th, 2012, 3:02 pm
So here is a small vid that clears things up.
http://youtu.be/YeFfNgXlrY4
doru
My vehicle: 2001 Mazda Tribute XLS v6
Postby was98strat - October 31st, 2012, 9:42 am
you can also get some additional lifting (and scuff prevention) but using a hockey puck between the lifting head and your lifting point!
was98strat
My vehicle: 2012 Escape XLT with MTX!!!!
Postby Stinky3377 - February 5th, 2013, 11:50 am
doru wrote:So here is a small vid that clears things up.
Awesome thanks...going to do the rear shocks this weekend and this helps a lot.
Stinky3377
Postby ALRUI - April 22nd, 2013, 2:25 pm
Hey Squishy are your images for the 2003? I looked at Alldata and the 09 seems different (either that or they didnt include good enough images).
ALRUI
Postby 2escapefmt - August 27th, 2013, 4:23 pm
have any of you really looked at the underside of your Escape-
have you thought about what you see as to what you want your jack under
2,000lb jack- would mean it could exert 2,000lbs on your flimsy unibody and possibly crush the area of contact
I always add wood between the jack & the----------- not frame as we old timers know these vehicles are way fragile
2escapefmt
Banned User
PreviousNext
Users browsing this forum: pjkeyzer and 25 guests
