XLS wheel?
Run into another E/M/T worthy of a shoutout?
Forum rules
Found an Escape, Mariner, or Tribute worth mentioning?
Thread title should list: color, model, location
Additional required information in the post: estimated model year , time and date, the motivation behind seeking that car out.
You never know - they could already be on Escape City!
XLS wheel?
Postby Escape94 - March 6th, 2016, 9:25 pm
Didn't spot an E per se but I did spot what I think is a steel wheel off of an 08 XLS. Good thing there's a reservoir clean up day in a few weeks. (Which I'll be participating in and leading a group as well :D )
Any confirmation on this?
Currently:
Escape94
E-C LEVEL 8
Re: XLS wheel?
Postby feh2goup - March 6th, 2016, 9:52 pm
Did any Escape use a 6-bolt hub? Great civic contribution on the cleanup!
2006 Suzuki Grand Vitara JLX-L, ~Maroon Red
2009 Escape Hybrid Limited AWD, Black, bought Jan.2013
- replaced ambient temperature sensor
- replaced hvac blend door motor
- updated SYNC software
- replaced water pump
- brake job
- replaced steering column
- replaced TPMS sensor
- multiple rear hatch water leaks fixed
- rattle in dashboard resolved as loose bolt in steering column coupler
- replaced underbody a/c lines to rear hvac
- replaced backup sensor
- replaced sway bar links
- replaced one outer tie rod (105,000 miles)
- replaced right front wheel bearing
- replaced ball joints
- another brake job
feh2goup
E-C LEVEL 5
Congratulations on reaching 750 posts!
Re: XLS wheel?
Postby MadMax - March 7th, 2016, 7:59 am
feh2goup wrote:Did any Escape use a 6-bolt hub? Great civic contribution on the cleanup!
No, all five bolt. I think that wheel is off a truck
Formerly: 2006 Mazda Tribute
E-C LEVEL 17
Re: XLS wheel?
Postby Escape94 - March 7th, 2016, 3:36 pm
you're right never thought about that. The design just looks similar.
Thanks, as a trail user, its fun to help out with and its good to volunteer. :)
Currently:
Escape94
E-C LEVEL 8
Return to Spotted!
