Best Mail Order Source for parts
Postby subdewd - October 5th, 2016, 11:53 am
I am needing to replace the battery cooling fans on 2007 mer mariner w/155000mi.
Anyone mail order before? wondering the best source.
Is 5M6Z10C659A the proper OEM number?
subdewd
Re: Best Mail Order Source for parts
Postby escape05xls - October 5th, 2016, 1:04 pm
rock-auto
2015 Escape Titanium 2.0 EB AWD
escape05xls
E-C LEVEL 6
My vehicle: 2015 Escape 2.0 EB AWD
Postby Twister - October 5th, 2016, 1:48 pm
I have great luck with rockauto, also with amazon.
Sent from my SM-N910P using Tapatalk
Twister
E-C LEVEL 1
My vehicle: 2003 Ford Escape XLS Sport
Postby ITBland - October 5th, 2016, 4:19 pm
Dealer Part, Rock Auto is not likely to have it. The new number is 5M6Z-10C659-B, and I got mine from FordPartsGiant.com, but I have also used Tasca Parts.
They are ~$300+ ship. You should also consider doing the Blend Door Motor/Actuator (AL8Z-19E616-F) That new part number is supposed to be much more reliable than the older models. Replacing it is a PIA, but it is only ~$30 and is a common problem. Good video on replacing it: https://www.youtube.com/watch?v=QFtgRL_PAkE
Note: FordPartsGiant usually drop-ships from a Ford Dealer, Tasca is a Ford Dealership.
ITBland
My vehicle: 2005 FEH and 2010 FEH
Postby Rex B - October 14th, 2016, 12:06 am
I check and use RockAuto first
Then I also use Amazon and also Google shopping
Via GoogleI found the best price on the blend door motor was WalMart. Picked up the Motorcraft part at the local Walmart Neighborhood (grocery) store, no freight
Rex B
Postby swinada - October 24th, 2016, 12:32 am
How can one test the cooling fans or the actuator door to see which one might be the culprit? I have no warning lights on but the car is misbehaving.
swinada
My vehicle: 2006 Ford Escape Hybrid AWD
Postby Jay2TheRescue - October 24th, 2016, 11:37 pm
Easiest way to test the door is to get a metal washer, and about a foot of fishing line. Access the air filter in the rear cargo area. Remove the filter, and place the washer on top of the door, and secure the other end of the line. Replace the filter and cover. Drive for a couple days. If when you check back, the washer has dropped inside, your blend door works. Use the fishing line to retrieve it.
I'm not sure of the procedure to test the fans. I know on my FEH I can hear them running when stopped in electric mode.
Jay2TheRescue
E-C LEVEL 10
Postby swinada - October 26th, 2016, 11:09 pm
thanks i guess i'm going fishing
swinada
Return to Hybrid Green Zone
