Does anyone elses 09+ rev too much?
Talk about anything related to your Escape, Mariner, Tribute, Maverick!
Postby Rochev - November 26th, 2016, 10:47 pm
My 2009 6F35 transmission wants to shift almost always around 3k rpm. If I take off quick, it takes its time shifting into higher gears so it's actually sluggish. It always wants to rev up high but I lift off the throttle a bit when I want it to shift lower, otherwise it revs up like a 4cyl. Does anyone else notice that? Or is mine messed up?
Rochev
E-C LEVEL 1
My vehicle: 2009 XLT V6 99k
Re: Does anyone elses 09+ rev too much?
Postby Rochev - December 9th, 2016, 2:41 am
Edited to make more sense and less to read :)
Rochev
E-C LEVEL 1
Postby underthetire - December 9th, 2016, 2:40 pm
Disconnect the battery for 10-15 minutes. The transmissions learn the drivers driving habits and adjust shift points accordingly. Also, i would change the fluid if you haven't done it in the last 30K. 09's were notorious for wiping out transmissions as the original ECU program made them over modulate the servos, wearing grooves in the transmission case. Ford had released a new ECU flash to stop that, but if the car had mileage on it before hand, wear was already started. My 09 had 2 trans rebuilds under warranty.
underthetire
E-C LEVEL 8
My vehicle: 2009 xlt sun and sync 2.5
My vehicle's name: Money saver
Postby Rochev - December 11th, 2016, 6:52 pm
Thanks for the reply. I had it flashed at Ford and removed the battery for a while. I change the fluid every 15k or so.
I also went on FORScan and wiped all memory. I guess it's just the way it shifts.
Rochev
E-C LEVEL 1
Postby underthetire - December 11th, 2016, 10:09 pm
My 4cy 09 shifts too early most of the time, and in normal driving always shifts before 3k unless I'm heavy footing it. Any hard shifts? Mine will hammer second gear at first shift if it's been sitting a while.
Sent from my A3-A20FHD using Tapatalk
underthetire
E-C LEVEL 8
Postby Rochev - December 11th, 2016, 10:39 pm
I've heard that a lot and from one person who owned one that there's a hard 1-2 shift. But mine glides into 2nd gear too early and smoothly. Sometimes it'll shift into 2nd at 5mph. When it's cold it'll wind up to about 2600rpm, hold it, and bump into 3rd gear, and it makes a loud "thump" in the rear end too and feels like the rear end lifts up a bit.
The only way I can describe it is that it's like a very overworked 4cyl. I have to baby it for it to shift below 2200rpm, and hammer on it after it shifts and let off slightly when I want it to shift etc. It just takes any enjoyment of driving from it. I've never wanted a CVT before this. :lol:
Rochev
E-C LEVEL 1
Postby Rochev - December 18th, 2016, 8:45 pm
I think the bigger problem is that it wont shift when it's cold and cold outside. It's like the ATF is molasses. It revs up and doesn't accelerate much and I have to let off for it to shift. It drives like a CVT when it's cold :worry:
Rochev
E-C LEVEL 1
Postby underthetire - December 18th, 2016, 11:44 pm
Are you using the mercon LV?
underthetire
E-C LEVEL 8
Postby Rochev - December 20th, 2016, 11:55 am
Yes, always
Rochev
E-C LEVEL 1
Return to Tailgate Chat
Users browsing this forum: Google [Bot] and 11 guests
