Grab handles
Enter your requests here. We'll try to find a guide for you!
Grab handles
Postby Bilbo - March 18th, 2008, 7:43 am
Anybody know if it's possible to add some of the grab handles to the interior of the 2008s that theyused to include in all of the others? I am also loking for part numbers or any suggestions.
Thanks for any reply.
Mrs Bilbo misses them.
Mrs B's:
2017 Silver SE 1.5 Eco boost. FWD
Retired.. :-( Redfire 08 XLS i4 4wd 71,771 miles RIP ESME
Bilbo:
2017 Magnetic SE 2.0 Eco Boost FWD.
Retired.. :-( Lil' "T" Black 10 XLT V6 Fwd 96,888 miles.
Retired.. :-( True Blue 2003 3.0L infidel fwd XLS
Bilbo
Re: Grab handles
Postby jpark - March 18th, 2008, 8:45 am
Bilbo,
I'll look up those part numbers when I get home on the 24th. Just a guess on my part, but I think the A-pillars and roof were carried over for the 2008 model year, so the two holes may still exist in the pillars under the plastic pillar covers.
Can you remove one of the covers and take a picture of the metal area underneath?
Maybe we can give wifey an early birthday present!
2016 Ford Escape Titanium 4WD, Magnetic Metallic, Charcoal Heated Leather, new 9/23/2015
- 2.0L EcoBoost I4, 6-speed auto, 301A, Sync 3/Sirius/HD, Panoramic Roof, Navigation
- Husky WeatherBeater 99741/23741 mats, Ford factory splash guards
2008 Ford Fusion SE FWD, Black, Charcoal/Red leather, new 2/23/2008, still strong and trouble-free
- 2.3L I4, 5-speed auto, Sync, Sport Appearance/Moon 'N Tune/Ambient Lighting packages, Husky WB 98301 mats
2013 Ford Escape Titanium 4WD, Ruby Red Metallic, Charcoal Leather, new 11/2/2012, sold 9/23/2015
2010 Ford Escape Limited FWD, Black, Camel Leather, new 4/22/2010, sold 11/2/2012
2007 Ford Edge SEL Plus AWD, Blazing Copper Metallic, Charcoal Leather, new 6/18/2007, sold 4/22/2010
2005 Ford Escape Limited 4WD, Redfire Metallic, Pebble Leather, new 6/4/2004, sold 6/18/2007
jpark
E-C Administrator
My nickname: JP
My vehicle: 2016 Escape Titanium 2.0EB 4WD
Re: Grab handles
Postby Bilbo - March 18th, 2008, 11:53 am
THanks,
I will try removing the plastic to check underneath. If I can do that and if I find the holes, I'll measure the hole spacing and taks some pics.
I'm not even finding a reference to the Assist Grab Handles as being an option on the 08s.
Edit: I think that there may be an issue. This thing has the side curtain airbags. I'd be afraid of getting into something that I'd be messing up. She wanted the ones overhead and not on the A pillars. ALso What I can' be sure of is how the airbag operation affects the overhead headliner or the plastic A pillar trim.
Mrs B's:
Bilbo:
Bilbo
Re: Grab handles
Postby jpark - March 24th, 2008, 4:30 pm
Good point...and you're right, you can't put handles where the side curtain air bags are located.
The A-pillars will stay in place if the side curtain airbags deploy (they couldn't, since they would create a projectile), but the headliner pulls away from the sides and exposes the bags. So you could put the handles on the A-pillars. But I'm also not sure if the A-pillars have the same shape and thickness as the 2001-2007 models.
jpark
E-C Administrator
My nickname: JP
Re: Grab handles
Postby Bilbo - March 24th, 2008, 9:21 pm
jpark wrote:Good point...and you're right, you can't put handles where the side curtain air bags are located.
From what I've seen neither the Escape, Mariner or Tribute has any grabs in 08 for loaded or optional equip. The salesman wanted us to go to a quality auto upholstry place but I figured that it would cost.
I wanted tocheck under the A pillar molding but then when I saw it, I couldn't figure out how it was fastened and I'm trying to not break anything. I think that the plastic trim piece is deeper than on my 03 and the 03 has depressions where the handle mounts. So they aren't interchangeable.
Well we have a bug deflector and window visors ordered and she wants the tinkerbell floor mats.....It's the wife's vehicle....
Mrs B's:
Bilbo:
Bilbo
Re: Grab handles
Postby jpark - March 25th, 2008, 7:13 am
Sorry 'bout that. You're right about the A-pillars on the 2001-2007 models---they have a "reinforcement" under the mounting points to prevent the pillars from being crushed as the handles are mounted and tightened.
As soon as I get a set of 2008 service DVDs, I'll take a look at the entire area and see if handles can be mounted anywhere.
jpark
E-C Administrator
My nickname: JP
Re: Grab handles
Postby Bilbo - March 25th, 2008, 8:42 am
Thanks,
I think that she's cool with no grab handles ...unless I can get them installed.
She has expressed an intrest in the step boards but they are like $350
Have you seen anything about the 08 key programming issue in TSBs.
The dealer said that they can't fix it for now.
We have two keys, the one works all fine. Mine doesn't program apparently. Key works. No buttons.
Mrs B's:
Bilbo:
Bilbo
Re: Grab handles
Postby jpark - March 25th, 2008, 9:24 am
I haven't seen any '08 TSBs on the keys yet. Did you try to have the system "learn" the key that doesn't work?
Here's the procedure for 2008 models (from the most recent owner's manual):
You can program your own Integrated Keyhead Transmitters or standard
SecuriLock™ coded keys to your vehicle. This procedure will program
both the engine immobilizer keycode and the remote entry transmitter
portion of the IKT to your vehicle. Note: A maximum of eight coded
keys can be programmed to your vehicle; only four of these eight can be
IKTs with remote entry functionality.
Tips:
• Only use Integrated Keyhead Transmitters (IKTs) or standard
SecuriLock™ keys.
• You must have two previously programmed coded keys (keys that
already operate your vehicle’s engine) and the new unprogrammed
key(s) readily accessible.
• If two previously programmed coded keys are not available, you must
take your vehicle to your authorized dealer to have the spare key(s)
programmed.
Please read and understand the
entire procedure before you begin.
1. Insert the first previously
programmed coded key into the
ignition.
2. Turn the ignition from the 1 (LOCK) position to the 3 (RUN) position.
Keep the ignition in the 3 (RUN) position for at least three seconds, but
no more than 10 seconds.
3. Turn the ignition to the 1 (LOCK) position and remove the first coded
key from the ignition.
4. Within ten seconds of turning the ignition to the 1 (LOCK) position,
insert the second previously coded key into the ignition.
5. Turn the ignition from the 1 (LOCK) position to the 3 (RUN) position.
6. Turn the ignition to the 1 (LOCK) position and remove the second
previously programmed coded key from the ignition.
7. Within twenty seconds of turning the ignition to the 1 (LOCK)
position and removing the previously programmed coded key, insert the
new unprogrammed key (new key/valet key) into the ignition.
8. Turn the ignition from the 1 (LOCK) position to the 3 (RUN) position.
Keep the ignition in the 3 (RUN) position for at least six seconds.
9. Remove the newly programmed coded key from the ignition.
If the key has been successfully programmed it will start the vehicle’s
engine and will operate the remote entry system (if the new key is an
Integrated Keyhead Transmitter). The theft indicator light will illuminate
for three seconds and then go out to indicate successful programming.
If the key was not successfully programmed, it will not start your
vehicle’s engine and/or will not operate the remote entry features. The
theft indicator light may flash on and off. Wait 20 seconds and you may
repeat Steps 1 through 8. If failure repeats, bring your vehicle to your
authorized dealer to have the new key(s) programmed.
To program additional new unprogrammed key(s), wait twenty seconds
and then repeat this procedure from Step 1.
HTH...
jpark
E-C Administrator
My nickname: JP
Re: Grab handles
Postby Bilbo - March 25th, 2008, 9:15 pm
Well thanks for this JPark.
Actually the scary part is the
"You must have two previously programmed coded keys"
and
"If the key was not successfully programmed, it will not start your
vehicle’s engine and/or will not operate the remote entry features. "
Now we only have 2 keys...
Currently the one key is fine but the second key doesn't function with the buttons. I can use the key to open and start manually though. I would not want to spoil that.
The Ford Mechanic said that they have tried programming it 4 times but no luck. They have talked to the company and they don't seem to have a fix...yet.
Mrs B's:
Bilbo:
Bilbo
Re: Grab handles
Postby Squishy - March 26th, 2008, 3:23 am
If they can't fix it can't you ask for a new key? Being under warranty and all...
The goggles, they do nothing!
The Garage:
Image Image Image Image
Squishy
Basket Case
E-C LEVEL 13
My nickname: Bev
Next
Return to How-To: Requests
