2004 Ford Escape Limited A/C compressor
Postby WAIrishPilot - July 2nd, 2016, 4:05 pm
Lookig for the part number for the compressor (including clutch) for a 2004 Ford Escape Limited 3.0 6cyl engine.
Thanks
WAIrishPilot
My vehicle: 2004 Ford Escape Limited
Re: 2004 Ford Escape Limited A/C compressor
Postby Mike Dee - July 2nd, 2016, 4:46 pm
Rockauto.com has several listed
Fordparts.com also has most parts listed as well
Mike Dee
E-C LEVEL 4
Postby WAIrishPilot - July 2nd, 2016, 5:18 pm
Problem with fordparts is they give me 3 different numbers.
WAIrishPilot
Postby 14theRoad - July 5th, 2016, 3:36 pm
WAIrishPilot wrote:Problem with fordparts is they give me 3 different numbers.
Did you read their descriptions?
YC-2520 - All Left Hand Drive Territories ; 3.0 V6 24V Dual Over Head Cam EFI Modular; FS-10, Compressor Only, New
YCC-157 - All Left Hand Drive Territories ; 3.0 V6 24V Dual Over Head Cam EFI Modular; New Loaded Compressor Assembly. Includes Clutch (19D786), Coil (19D798), Pulley (19D784) And Oil, Ford Retail Spec
YCC-241-RM -All Left Hand Drive Territories ; 3.0 V6 24V Dual Over Head Cam EFI Modular; Exchange Part (Re-Manufactured), Ford Retail Spec, Remanufactured, Complete Assembly Includes A/C Compressor And Clutch
So, either YCC-157 or YCC-241-RM are you choices for what you want. You just need to decide new or remanufactured.
If you're going to go with remanufactured I'd recommend aftermarket. For new, Ford is best. If you go with Ford, make sure you are shopping under Auto Nation Ford White Bear Lake. They've got the best prices for Ford Parts (better than Rock Auto in most cases) and cheap shipping.
14theRoad
E-C LEVEL 4
Postby WAIrishPilot - July 7th, 2016, 2:40 pm
I want new for sure. I am willing to go aftermarket on some things. But the A/C system I want to work right.
I went to fordparts.com and it is being stupid on me so I can't select a dealer. Figure that out later.
I will go find that motorcraft YCC157 part. Amazon has it for 280.
Thanks for the help.
WAIrishPilot
Return to Part Numbers
