Who has switchback front turn signals
Postby backroad101 - July 12th, 2016, 7:05 pm
So I got these switchback turn signals
http://www.ebay.com/itm/131848417600?_t ... EBIDX%3AIT
Along with this wiring adapter kit
http://www.ebay.com/itm/151924557304?_t ... EBIDX%3AIT
They work perfectly except for one problem. Each harness has 2 load resistors as you can see in the pics. When the lights are off, one resistor cools off and the other remains very hot to the touch. Is this right? Does not seem right to me. Don't feel comfortable about this so returned everything to stock for now. Thoughts?
2011 Escape XLT
http://www.escape-city.com/viewtopic.php?f=23&t=23610
backroad101
E-C LEVEL 4
Re: Who has switchback front turn signals
Postby Jay2TheRescue - July 12th, 2016, 11:59 pm
I had them until I was due for my safety inspection, and the state made me remove them. You only need the load resistor on the lead for the flashing amber portion of the bulb. The white portion does not require a load resistor.
Jay2TheRescue
E-C LEVEL 10
Postby backroad101 - July 13th, 2016, 7:25 pm
So the harness kit I bought has 2 resistors per side. There are other kits on ebay that have one resistor per side. What would be the reason for having 2 resistors per side?
I am thinking about returning what I bought
and get this
http://www.ebay.com/itm/3156-3157-3taps ... RTM2247628
Thoughts?
2011 Escape XLT
backroad101
E-C LEVEL 4
Postby Jay2TheRescue - July 13th, 2016, 11:29 pm
backroad101 wrote:So the harness kit I bought has 2 resistors per side. There are other kits on ebay that have one resistor per side. What would be the reason for having 2 resistors per side?
and get this
Thoughts?
Some cars will trigger a fault with the computer because the system thinks that the bulb is out, so in those cases, all LEDs need to have resistors installed. On the 01-12 Escapes, resistors are only needed on circuits that flash with the turn signals.
Jay2TheRescue
E-C LEVEL 10
Postby backroad101 - July 14th, 2016, 7:23 pm
So all the pre-wired harnesses with one load resistor I have seen that they say they are for non-switchback bulbs. Do switchbacks require dual resistors per side?
I tried them again. Plugged everything in and kept all lights turned off. The resistors stayed cool after a minute or two plugged in. Tested the lights to see which resistor was for the amber and which for the white. The one for the white heated up when the white was on then the one for the orange heated up when I turned the signal on. Turned off all the lights, the one for the orange cooled off and the one for the white stayed very hot for at least 5 minutes until I just unplugged everything.
2011 Escape XLT
backroad101
E-C LEVEL 4
Postby Jay2TheRescue - July 15th, 2016, 8:53 am
Cut the one for white out and terminate the ends.
Jay2TheRescue
E-C LEVEL 10
Postby Escape94 - July 15th, 2016, 6:20 pm
Me! I just installed the VLEDs kit a few weeks back. They are crazy bright. Everything was plug and play. Only thing I didn't do was install the dimming circuit for the headlights. You'll pay up a bit but it's well worth it quality and simplicity to install.
Currently:
Escape94
E-C LEVEL 8
Postby Buran - November 20th, 2016, 1:49 am
I'd like to get the superbrightleds switchbacks along with this flasher that will eliminate the need to install resistors. I don't want to tap into any more wiring than I already have (powering up the halos in the Spyder headlamps is it so far). That is, if I'm not stymied by the smart junction box. My web-digging is saying I might be, yet for some reason that site insists the flasher is compatible.
Buran
My vehicle: 2011 Ford Escape Limited FWD
Postby Jay2TheRescue - November 20th, 2016, 7:06 pm
Buran wrote:I'd like to get the superbrightleds switchbacks along with this flasher that will eliminate the need to install resistors. I don't want to tap into any more wiring than I already have (powering up the halos in the Spyder headlamps is it so far). That is, if I'm not stymied by the smart junction box. My web-digging is saying I might be, yet for some reason that site insists the flasher is compatible.
The site is wrong. A 2011 Escape has a SJB, and does not have a flasher. If you bought the flasher it would not solve the problem, as there is nowhere to plug it into a 2011.
Jay2TheRescue
E-C LEVEL 10
Postby Buran - November 21st, 2016, 3:29 pm
That's what I was figuring as I continued digging. I'll probably pick up the vleds.com set as they offer inline resistors that don't require any splicing. This kit is probably my best bet.
Buran
Next
Return to Electrical Mods
