Custom 2nd gen Ford Escape turbo!
Engine, transmission, exhaust, drivetrain, more
Postby Escape94 - December 26th, 2016, 8:44 pm
Alright, so this made its rounds on social media, so I'll share it here. This just goes to show anything is possible with money and determination. Though I personally do not like the position of it, plus the fact that there will be a lot of lag and losses in the system. To top it if I'm not sure the CD4E will like that. Just because you can doesn't mean you should. But hey! To each their own :cigar: have at it e-c! Thoughts??
Currently:
Escape94
E-C LEVEL 8
Re: Custom 2nd gen Ford Escape turbo!
Postby Linna - December 26th, 2016, 9:33 pm
This is hilarious. Wonder if there are any dyno run videos of this to amaze us with the power output.
Linna
E-C LEVEL 6
Postby 14theRoad - December 27th, 2016, 3:03 pm
Actually the application of a rear mounted turbo has been around for years.
Hellion and STS (Squire Turbo Systems) both make rear mount systems for cars like the Camaro, Mustang, Corvette and Mopar V8 applications.
https://www.google.com/search?q=sts+rea ... CGQQsAQIPw
http://www.americanmuscle.com/hellion-t ... &GID=42611
Most V8 cars and V6 SUV's have tiny engine compartments that already run hot. Adding a Turbo to the mix creates problems in how to best dissipate the heat while still maintaining respectable power.
Anyways, the kits that are available are designed to fit under the car. Not like this one-off. That being said Escape94, In this instance I agree. Just because you can doesn't mean you should. To each their own!
I think it would be pretty respectable if they could just get it tucked under so that it doesn't hit every rock and pebble on the road. Turbo lag I'm sure is present given the size of the turbo they used and the piping to the application it's being used for.
Do you have any info on the year escape or what tag line the images use? I'm sure there is a dyno somewhere if this a legitimate vehicle.
14theRoad
E-C LEVEL 4
Postby Escape94 - December 27th, 2016, 8:35 pm
Linna wrote:This is hilarious. Wonder if there are any dyno run videos of this to amaze us with the power output.
14theRoad wrote:Actually the application of a rear mounted turbo has been around for years.
I can try to track it down, I think its an 08 or early production 09. People online did suggest this was a home brewed STS system. I first saw this on Instagram and then shared it to the escape pages on facebook.
Currently:
Escape94
E-C LEVEL 8
Return to Powertrain Mods
