How To: 2005-2008 Engine Swap 2.3L to 2.0L
Engine, transmission, exhaust, drivetrain, more
Re: How To: 2005-2008 Engine Swap 2.3L to 2.0L
Postby gilljason - August 17th, 2015, 11:22 pm
Mich_rod ,
how did your swap go?
I'm getting ready to do one on our 05 Tribute from a the stock 2.3 (spun bearing) to a 2.0 from a 2010 focus.
what year was your engine you were swapping to?
gilljason
Postby Pepperbird - September 3rd, 2015, 9:24 pm
Would a 2000 Mazda tribute v6 3.0L Transmission fits in 2005 Ford escape XLT 2.3L?
Pepperbird
Postby MazdaShark - September 3rd, 2015, 9:26 pm
A 2001 you mean? The transmissions didn't change till 08 it just depends on if its 4 wheel or not.
MazdaShark
Banned User
E-C LEVEL 3
Postby Dark_Passenger - September 3rd, 2015, 9:46 pm
That is definitely a situation that I would have to do some research on. As far as fitting, yes it would "fit". Like mazdashark said the transmission are the same (CD4E). However, the electrical components, I would guess, are entirely different. You would most likely have to do a full swap of the ECU and all related systems.
Dark_Passenger
My nickname: Maintenance Master
My vehicle: 2006 Ford Escape XLS
Postby MazdaShark - September 4th, 2015, 4:14 pm
TCU and ECU would probably definitely need a swap or reprogram.
MazdaShark
Banned User
E-C LEVEL 3
Postby Pepperbird - September 8th, 2015, 1:30 pm
Thanks for your replies!
Pepperbird
Postby j serrano - October 11th, 2015, 3:44 pm
Hi i got a 2005 Mazda Tribute and i found a motor 2.0 on craigslist a guy from the garage he tried to swap with this engine but he said he can't make it work i also wanted to buy the engine but he informed me to do more research because it didn't work for him the motor is 2006 2.0 Focus with only 63,000 i want to see if theres more people is this forum that alreadyt made the swap and how they are doing with the swap.
Thanks
j serrano
Postby Stangc427 - November 10th, 2015, 3:11 pm
Hi I'm new to the forum and looking for a little help. I love your write up and Im neck deep in the same repair.
Everything went smooth until the wrist pins walked out of the bores and destroyed the block on my fresh rebuild. Machine shop (who was very reputeable mind you) threw up there hands and offered me a kind hearted Im sorry. All four Pins walked out in the same direction and gouged all four cylinders. This happened in less then 100 miles!
Anyway, Im back to square one and Escape blocks/motors are crazy expensive plus Im in for a lot of money in parts already. What all would it take to use a Fusion 2.3? You mentioned staying away from VVT versions but I think they all were. Does an intake came swap from my Escape cure it or would that entail and entire head swap, which Im not opposed to. I just need a quick and reasonable solution for a new bottom end. Hind sight being 20/20 I would have gone with a reman motor for $2500 and warranty. Thanks
Stangc427
My vehicle: My inlaws 05 Escape
Postby escape05xls - November 12th, 2015, 1:36 pm
j serrano wrote:Hi i got a 2005 Mazda Tribute and i found a motor 2.0 on craigslist a guy from the garage he tried to swap with this engine but he said he can't make it work i also wanted to buy the engine but he informed me to do more research because it didn't work for him the motor is 2006 2.0 Focus with only 63,000 i want to see if theres more people is this forum that alreadyt made the swap and how they are doing with the swap.
Thanks
That would be a fully custom job. You are going to want to find an engine that came in the escape/tribute/mar stock. In 2005 it was a 2.3L
https://en.wikipedia.org/wiki/Mazda_L_e ... 2CL3-DE.29
The 2001-2004 used the 2.0 Zetec.
2015 Escape Titanium 2.0 EB AWD
escape05xls
E-C LEVEL 6
My vehicle: 2015 Escape 2.0 EB AWD
Postby escape05xls - November 12th, 2015, 1:38 pm
Stangc427 wrote:Hi I'm new to the forum and looking for a little help. I love your write up and Im neck deep in the same repair.
Can you just find a used one from a wrecked escape/tribute/mar with no engine damage?
escape05xls
E-C LEVEL 6
PreviousNext
Return to Powertrain Mods
Users browsing this forum: No registered users and 13 guests
cron
