Full Size Spare Relocate
Re: Full Size Spare Relocate
Postby Drjames - November 15th, 2016, 10:56 pm
I try to keep the cargo area as open as possible for the built-in storage/camp kitchen cabinet and sleeping room for solo camp trips. Thus trying to keep the spare outside and utilize the area that stock spare goes in for storage.
2001 Ford Escape budget adventure rig
Roof basket w/ diy bike racks and shovel mount
Aftermarket hitch and trailer lights
Blacked out grille,Headlight eyelids
Cargo management/Kitchen
AT tires
Stickers!
Drjames
My vehicle: 2001 Escape 4x4 xlt
Postby Larry LGT 165 - November 21st, 2016, 6:01 pm
I had the swing away spare tire carrier on both a '71 Blazer and a '74 Bronco II before they were even known as a II. Both were great but did rattle a bit.
Surely somebody out there (California) must offer a simple kit for Escapes.
They also make rear luggage carriers for the hitch that swing up vertical when not in use. Could you make a simple spare mount out of this principal? Just swing it down to access the rear cargo area. I've seen similar on motorhomes with rear storage compartments.
Larry LGT 165
Postby Half Assed - November 21st, 2016, 8:45 pm
Not real familiar with the 01-04 escape, but maybe you could cut out the spare tire well inside the trunk and make it bigger to fit a fullsize spare? Or cut it out completely and weld it flat and mount the spare underneath like the 05-07. This of course is if you could even fit a full size spare underneath or inside. Tape measure time. :yes:
"Forget your lust for the rich man's gold,
all that you need is in your soul." -Lynyrd Skynyrd
Half Assed
E-C LEVEL 1
My vehicle: 05 Escape 2.3/5spd
Postby Drjames - November 22nd, 2016, 10:05 am
I do like the idea of a swing down cargo carrier of sorts. Would just go with the hitch mount tire carrier that lays down flat to access that hatch but they are $250+. As for re-fabbing the stock spare area, Im no welding guru and hopefully getting the spare out of there to have room for camping gear....or a maybe pressurized on-board water system :rockon:
AT tires
Stickers!
Drjames
Postby Squirrel - November 22nd, 2016, 10:26 am
Drjames wrote:I do like the idea of a swing down cargo carrier of sorts. Would just go with the hitch mount tire carrier that lays down flat to access that hatch but they are $250+. As for re-fabbing the stock spare area, Im no welding guru and hopefully getting the spare out of there to have room for camping gear....or a maybe pressurized on-board water system :rockon:
http://www.ebay.com/sch/i.html?_from=R4 ... R&_sacat=0
Squirrel
E-C LEVEL 4
My nickname: Squirrel!
Postby Drjames - November 24th, 2016, 2:22 pm
Think Im gunna pull the trigger on the whole set up next paycheck. Gunna go with the rugged ridge HD mount. After researching and measuring and re-measuring, in theory it should work. Going to mount it right where the rear plate is. The mounts footprint is 8''x10'' so I should have plenty of room to mount securely. Also the mount put the spare lugs 10'' away from the hatch witch should be enough to have the tire clear the rear bumper,because it will hang a bit lower than the bumper its self.
A back plate on the inside of the hatch along with a silicon caulking or bushing of sorts in the both holes (to reduce vibrations and movement if there is any) should create a secure mounting area. The mount its self is made for a 35'' tire on a jeep so I have no doubt in the strenghth in the product.
Also going to try this http://landroverforums.com/forum/discov ... 8-a-36063/
to mount a hi lift.
Ill be sure to post pictures of the process and final product. I figure worst case I would have to get stronger door shocks
AT tires
Stickers!
Drjames
Postby Sevencycle - February 14th, 2017, 5:55 pm
I relocated mine to the roof rack. Its a full size alloy wheel/tire. I added 2 beefed up cross pieces to support the wheel. I bought a Yakima spare tire mounting kit p/n 8007076. I had to fab a new base plate to attach it to the cross pieces using some muffler hanger u bolts that conformed to the cross pieces perfectly. I used the attach plate, ubolt and vbolt from the kit as is. There was some other fab required as well w some aluminum square tubing. The tire mounts right side up instead of upside down. I also bonded a piece of rubber to the attach plate to prevent marring on my powder coat.
I attached some eye bolts to the rack side rails for using a 3point ratchet strap that I got from Home Depot for under $20. Most other suppliers of a similar product were charging over $90. I have some pictures but I am waiting for approval to attach.
G. Ripley
Sevencycle
My vehicle: '02 Tribute ES 4x4
Previous
Return to Exterior Mods
Users browsing this forum: FRENCHY and 24 guests
